Permis de construire ou déclaration de travaux ?
nayomad
Re: Permis de construire ou déclaration de travaux ?
Message par nayomad »
Good morning!
Converting a garage into a living space can be a rewarding project. Make sure you follow all local regulations and obtain the correct declaration of works. When removing interior walls, always prioritize safety with a sledgehammer, crowbar, dust sheets, and gear. Also, consider consulting a structural expert to install a Sanford support beam if needed for load-bearing walls. Proper insulation for the sliding glass door will complete the transformation efficiently.
